Re: fix one problem and a new one arrives here I g
Posted by Janicholson on July 07, 2005 at 19:15:59 from (66.173.50.66):
In Reply to: fix one problem and a new one arrives here I go ag posted by lekander883 on July 06, 2005 at 18:38:35:
My short answer is: If it is a lift only, one way main cylinder, and the oil is comming from the top of the cyl where the chrome rod comes out, the cylinder is "bypassing". This means the piston is leaking oil past cups, or o-rings. If you tear it down make sure the cylinder is not scored on the bore. It should be as smooth as glass. if water was allowed into the cyl (long exposure outside) the cylinder may be pitted causing seal dammage. the only way to fix it is to hone the cylinder. (usually a good hydraulic shop can do it). If it has been a long time sence it was uswd, and maybe left in the up position, Id check the oil in the tractor hyd. then gently/slowly lift the loader up to the top INCREMENTALLY. catching the oil in a pan. Then try the loader in use. If it seems ok use it a bunch it may just need to be operated. If it leaks down all the time, it is to the shop you will be taking it.
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
