Re: Farmall Distributor-Horizontal/Vertical
Posted by ChadS on July 21, 2005 at 05:41:20 from (66.228.96.167):
In Reply to: Farmall Distributor-Horizontal/Vertical posted by Pappy on July 20, 2005 at 23:51:19:
Horizontal distributor gear is a straight, fine tooth gear, where the vertical, is a slanted course gear, I am thinking the vertical distributors were Delco distributors and use a different set of points than the IH. Kinda looks like the points used in olivers, Molines etc etc,,, Should either have a tag with delco on it, or the IH casting number stamped in the side. Dont know if this helps,, dotn think they are interchangable, unless you change the gear. Chad
Post a Followup
