I have a couple of steel plates that bolt on the cooler where it would attach to the block. One plate has a hole where I can attach an air hose. While pressurized, I stand it on end and fill it with water. Watch for any bubbles.
Most likely the oil cooler is not your problem. Cooler failures almost always result in oil entering the coolant. Often the first indication is oil coming out of the Radiator.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
