Posted by dave westlund on April 06, 2009 at 19:36:16 from (69.46.194.235):
My H farmall had disk brakes and I've been told that there was an update kit to convert from band brake to disk brakes. My disk brake setup is different that super H's. I'm trying to locate a tapered compression spring that goes around the adjustment screw on the inside the brake housing.The the screw points upward out of the housing. Case Ih has retired the spring and the spring on both sides are broken so I don't know what it should look like. Any idea where they can be found?
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
