Re: Int'l. 300 pto
Posted by TDK on July 28, 2005 at 20:11:39 from (64.12.117.13):
In Reply to: Int'l. 300 pto posted by davids on July 28, 2005 at 19:09:11:
With tractor engine off, remove adj. screw cover, loosen locknuts and turn screws out about 3 - 4 turns. About half way between the slots that the pto lever latches in is a punch mark, there's also a punch mark on the pawl on lever. These marks are somewhat hard to see on a Utility tractor. When the marks are aligned the pto should turn freely with a rod or punch placed in the 5/16 hole in pto shaft. Now, turn the adj. screws in until they are reasonably tight and lock the nuts. Move the lever up and down all the way several times. Back the adj. screws one turn & lock the nuts. Pto shaft should now turn freely when the punch marks are in line and at no other position. If pto is still tight, then back adj. screws out 1/2 turn and recheck. Sometimes due to wear in the pto lever and linkage, etc., lining up marks will not work. In this case I usually have another person slowly move lever until the pto turns free, this would be the same as using punch marks. Or you can replace the bushings in pto lever at mounting point, etc.
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
