Re: stuck head studs on M - help
Posted by Slappy on August 17, 2005 at 03:25:09 from (143.88.85.82):
In Reply to: stuck head studs on M - help posted by Farmerbash on August 16, 2005 at 12:57:47:
Be really careful using the double nut option when getting studs out. The nuts are at the top of the stud and owing to the length of the studs, you will generate a lot of torque when you put a wrench on them. My advice is to go to Sears (or where ever) and invest in a stud puller. They usually run $35 or so, but it beats having to pay to have a broken stud or studs removed.
You probably won't need heat if you use a stud puller, but if you do need heat to break them free, I would not heat them red hot. The studs are hardened and too much heat will ruin the temper and possibly allow you to twist a stud off when you touque the head down. If you have to heat a stud to cherry red to remove it, I would replace it with a new stud.
Post a Followup
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
