Re: gen to alt????
Posted by John T on August 28, 2005 at 18:37:47 from (66.244.90.98):
In Reply to: gen to alt???? posted by jpl on August 28, 2005 at 11:04:01:
jpl, if it's truly a "One Wire" Alternator as you claim and NOT a GM 10 SI 3 wire alternator and assuming youre already set up for Negative ground and this is a Negative ground alternator???? (Be sure the alternators ground (+ or -) is the same way your battery is installed ?????????? If not post back !!!!!!!!!!! In case you havent already upgraded wire size to accommodate for maybe a 30 or 40 amp or more alternator to replace an original maybe 20 amp Generator,,,,, Run a 10 Gauge wire from the Alternators big main output post up to the Load (NOT to battery) side of the ammeter. That is to replace the wire from the BAT terminal on the old Voltage Regulator or Cutout Relay up to the ammeters load terminal which may have only been a 12 to 14 Gauge??? Run a 10 gauge wire from the ammeters other SUPPLY side terminal to a hot ungrounded battery feed, which is often taken from the big lug on the starter switch. This is to replace the original hot supply voltage to the ammeter which may be a 12 or 14 gauge. Again, make sure the alternators ground matches how your battery is installed and then simply upgrade a couple wires (ammeters supply feed and alternator output load circuit) from 12 or 14 Gauge up to 10 Gauge. If youre just now switching polarity, the ammeter leads (supply and load sides) need to be swapped or it will read bass ackwards. The coil leads get swapped if you change polarity also. John T Nordhoff in Indiana, retired electrical engineer
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
