Re: A couple of Super C questions
Posted by RayP(MI) on September 08, 2005 at 18:11:42 from (64.25.199.4):
In Reply to: Re: A couple of Super C questions posted by El Toro on September 08, 2005 at 16:38:20:
I would be very careful with a puller - I couldn't get one to fit properly, and was afraid that i would break the pulley. Finally resorted to drilling two holes in pulley, across from each other in the space between the hub and the V, and then fabricating a puller out of two bolts, and a strap of 1/2" by 3" steel. Put a large socket on the crank shaft, tightened the bolts, and it walked right off. If I remember right I used an impact wrench very gingerly to tighten the bolts.
Post a Followup
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
