Re: gererator wiring
Posted by holcombwa on September 12, 2005 at 05:46:39 from (209.206.169.240):
In Reply to: gererator wiring posted by MNred on September 11, 2005 at 19:01:35:
Just got done fighting this battle on my "A". Don't know if yours is similar, but here goes. The field post on the generator (on my tractor the one nearest the engine block on the generator)went to the field post on the regulator which was the terminal farthest to the left when the terminals were facing away from you (I mention all this because on my old one there was no indication at all as to which terminal was which and figure you might be in the same situation). Wire to the positive side of the anmeter went to the "bat" post on the regulator (middle one on mine). Wire to the lights went to the "L" (load) terminal on the regulator (one on the right when facing away from you). The armature "A" wire from the generator went to a terminal on the underside of the regulator. The ignition switch wire went from the distributor/mag setup straight up to the switch without interruption. The positive side of the anmeter was connected to a wire from the positive side of the battery by way of the switch on the starter. I cleaned and regrounded everything, polished the commutator to bright with crocus cloth, my brushes were fine but had to free up the springs a bit, AND the big thing, as per Nebraska Cowman, I shorted a wire from generator field post to a good ground and then she started working great and has every since. Don't know if that helps or not with yours, but good luck with it. Stan
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
