Re: Trip loader; How do you hook up???
Posted by JB2 on September 20, 2005 at 21:04:55 from (69.196.154.214):
In Reply to: Re: Trip loader; How do you hook up??? posted by Paul Gabriel on September 20, 2005 at 18:22:08:
Two methods of hookup: For loader itself connect the 2 single acting cylinders together and put a T fitting in the line by the right hand cylinder. From the T fitting connect a hydraulic hose that will either connect to the remote outlet on the back of the tractor for option 1 or to the lever controlled output of a single acting control valve as in option 2. 1)Cheap method if your tractor has a remote cylinder outlet at the rear. Using this method the 3pt control lever is used to raise and lower the loader. Position the 3pt control lever in about mid position of UP/DOWN then turn the valve at the front of the seat labeled SHUT OFF/ON to I believe the OFF position. Now the 3pt control lever controls the flow of the hydraulic oil to the rear remote outlet. Bad thing is you can’t use 3pt and loader together. I once saw a 434 that had a pipe fitting in that big plug in front of the seat and the hydraulic hose to the loader was directly connected to the pipe fitting but the proper part is a banjo fitting. 2)Installing a separate single acting hydraulic control valve and bolting it to the loader frame on the right side if you are right handed. Position it so that it is easily operated from the tractor seat. To connect this valve into the existing hydraulic system, IH used to sell a kit that replaced the high pressure (small) line that runs from the hydraulic pump to the reservoir under the seat. The kit consisted of 2 pieces of pipe, one long piece that ran from the hydraulic pump back to just in front of the brake pedal and then it pointed skyward and terminated in a male hydraulic hose fitting. This would be plumped using a short piece of hydraulic hose into the inlet port of the hydraulic control valve. The outlet port of the control valve would be connected via another short piece of hydraulic hose to the second piece of pipe that would then connect back to the reservoir under the seat. The good thing about this connection method is both loader and 3pt can be used together, like with a back blade on 3pt and loader. Hope this helps, to bad I can't draw pictures on this site. JB2
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
