Re: Check Ampere Gauge
Posted by Nat on October 06, 2005 at 20:29:34 from (64.80.108.52):
In Reply to: Re: Check Ampere Gauge posted by Easy on October 06, 2005 at 18:21:38:
Quite simply, the needle should move to the right of center while the tractor is running, and to the left of center when the tractor is not running. There's no set amount of needle movement for each specific tractor, contrary to what some people would have you believe. The charging systems are essentially the same on all these Farmalls, and the amount the needle moves depends on many variables:
1. How much load is on the electrical system (lights, etc.).
2. How good the charging system is (generator and regulator, or alternator).
3. The condition of the battery, or how much you had to crank the tractor to get it running (a weak battery will cause the needle to move farther to the right while the tractor is running).
In a nutshell, if it moves to the right when the tractor is running, it's working fine.
Post a Followup
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
