Water good , in oil -bad ! ( long )
Posted by Randy-IA on November 04, 2005 at 16:30:43 from (209.152.95.37):
Hi all , I took the drain plug out of the M . About a cup of water came out before the sludge started which by the way looked like whipped milk . So I removed the pan . It all look's good up in there but the oil pump pickup was about 99% plugged with gunk and grass and yuk . Took it apart and cleaned it . The bottom of the piston's don't have any burned on oil deposit's and the sleeves looked shiney , no crosshatch left but also no serious wear mark's or scratches as far as I could see so I put it back together and filled it with oil and started it up . The pan doesn't leak but the front crank seal does . Is this a doable fix with the motor still in the tractor ? I also drained some gear oil out of the front of the transmission and guess what ? Oil looked like whipped milk ! Water is in everything ! I know that the antifreeze can't make it to the final drive so I'm hoping the water in both of them was just condensation . There was new antifreeze in the motor when I brought it home and it doesn't appear to have dropped any but I haven't ran it much either . 13 Gallon's of gear oil ! That'll empty out the bank account ! But maybe it'll quiet the beast down on the road . All 9 gear's work good but it growl's going down the road which might be because the gear oil was so low in the box that I couldn't see it through the check hole with a flashlight AND it has water in it . I'm just going to put new oil in it and if it doesn't all run out onto the ground I'm going to run it that way till I get around to fixing it right , maybe next year . It also start's very easy so far but it does miss at low rpm's to about 1/3rd throttle . 1/2 throttle on up it seems to do OK with no load but since I ripped off the muffler to get the thing home without it breaking off it spit's fire when it miss's and when it's moved to wide open very fast . I haven't checked out the the hydrualic oil yet ( I suspect there isn't any ) and the belt pulley won't engage . It doesn't actually have the pulley so that's something I'll have to scrounge up sometime . All in all , if the crankcase doesn't fill up with antifreeze , I'm satisfied . Now I think that I did my normal job of paying too much for it but it's not that bad . Just don't tell me I got took - That's the story of my life , I trust everyone . Ya know what W.C. Fields said ( or was it P.T. Barnum ? ) about suckers - I represent that statement ! I'm not able to change now ! Take care ...Randy
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
