Re: Narrowed Down
Posted by Slappy on November 10, 2005 at 05:10:31 from (143.88.85.82):
In Reply to: Narrowed Down posted by James.01 on November 09, 2005 at 19:25:23:
The easiest thing will be to pull the head, drop the oil pan, pull the bearing caps and push the pistons out through the top. If you have a ridge, you may need to buy/rent a ridge reamer (measure the cylinder diameter at the ridge first - it can be handy later).
I didn't read your last post, and so am not familiar with the original problem. That being said, I don't think I would recommend replacing/reparing just two of the pistons. I would suggest that whatever you do to #1 and #3, you also do to #2 and #4.
Post a Followup
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
