Re: 544DEISEL STARTING WOES AGAIN
Posted by the tractor vet on November 15, 2005 at 06:19:56 from (4.124.91.156):
In Reply to: 544DEISEL STARTING WOES AGAIN posted by dave from MN on November 15, 2005 at 04:34:35:
First off they came with two 6 volts and if they are of the 650 amp size that should be enough . Now if the injecton pump is in good shape and the cranking pressure is correct and the injectors are crackin at the correct pressure and the timming is correct and the engine has good compression then it should start cold down to around freezing . Now the COLD start is not on the throttel it is in with the shutdown cable and it works when the shutdown is placed HALF WAY between run and stop . THe stock ground cable is one of them flat braided ones and is fine the pos termianal of 00 is fine . If you want you can get away with one Group 31 battery of around 1000 cca . But this is a diesel and it is not going to start like a gasser when it gets cold . You will have to have a block heater on it and throw away you either can or you will end up killing the engine if you have not already knocked the rings out of it . You can not believe how many engines that i have tore down to find two or three pice rings in them from either.Now i am not tryen to be a smart aress here but you would be much better off with a gasser one heck of alot cheeper to fix and easier to work on and it will start anytime.
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
