Re: installing cub governor
Posted by El Toro on November 16, 2005 at 17:39:58 from (64.12.117.13):
In Reply to: installing cub governor posted by Rich Lorenz on November 16, 2005 at 15:26:05:
You need to remove No1 sparkplug near the radiator. You need to bring No1 piston up on the compression stroke to TDC. You need hold your thumb over the plug hole while someone slowly hand cranks the engine until you feel compression against your thumb. Then you watch for the notch on the damper pulley as the engine is slowly turned until the notch is aligned with the pointer. The No1 piston should be at TDC. Rotate the rotor to No1 plug wire and install the distr. Make sure your plug wires are installed in the correct order on the cap. The firing order is 1-3-4-2 and should look similar to this: 2-1 4-3 Post back if need further help. Hal
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
