Re: M Engine
Posted by wareagle on November 17, 2005 at 15:01:13 from (64.178.237.68):
In Reply to: Re: M Engine posted by captaink on November 17, 2005 at 07:33:50:
The Tractor has stepped or dome pistons. I will probably not work the tractor appreciably as we have other stuff to get dirty but like to make good sounds and show it to friends. Mostly it's a challenge. Can I check for bore taper using ring end gap measurements from the bottom of the stroke to the top of the stroke. I get your point about the effects of taper. I thought I knew a little about engine building but I never considered taper since all my other projects were Automotive and followed engine machining. Is a sleeve change easy enough or is it hard to pull the old ones and push the new ones back in on this engine?
If this tractor was originally a distillate engine, was it a super M as I thought or was the Super only for those higher compression engines? Also, are there differences between a distillate carb and a gasoline carb?
Another question.. Most of the M tractors I have seen were without fenders including ours and also our 400. Did people just remove these and loose them or was this an option?
Post a Followup
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
