Re: 12 Volt for Farmall C (Bob M)
Posted by John T on November 28, 2005 at 12:37:02 from (66.244.90.98):
In Reply to: 12 Volt for Farmall C (Bob M) posted by DelMN on November 28, 2005 at 11:56:52:
Del, I dont have Bobs schematic handy, but I know hes about the best source Ive seen on these farmalls and would believe n trust regarding their wiring. Believe him before meeeeeeeeeee. That being said, is there EITHER a 10 ohm current limiting protection resistor in your alternators excitation circuit from the coils high input side or the ignition switches output ORRRRRRRRRRRRRRRRR a 5 amp 50 PIV volt diode TO THE LIL SIDE NO. 1 ALTERNATOR TERMINAL????? CUZ if not, when you trun off the ignition switch the alternator is back feeding the coil and keeping voltage to making her still run EVEN WHEN ITS SWITCHED OFF I highly recommend a 10 ohm resistor in the circuit that excites the alternators lil side No. 1 terminal for protection. although she may be fine forever even without it, better safe then sorry I say. Thennnnnnn if she still back feeds the coil and runs when shut off, simply add a 5 amp 50 PIV volt diode (one way current flow check valve) in series in the circuit after the voltage feed (coil or switch) and before the alternator to stop that run on problem. NOTE the diode MUST be wired + from feed and - to alternator so it can feed current into the alternator BUT NOT allow it to flow out of the alternator to feed the coil. Soooooooo, do you have a diode or a resistor in the alternators lil No. 1 excitation circuit???????? If not, therein lies the problem of why she runs even after shes turned off. The diode dont really need to be 5 amp rated, thats just what I use as its easier to wire.
See what Bob n the other good gents have to say. John T
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
