Re: M Farmall Rings
Posted by wareagle on November 30, 2005 at 14:28:04 from (64.178.237.68):
In Reply to: M Farmall Rings posted by wareagle on November 30, 2005 at 05:15:09:
You guys are right, I left off the fact that the engine is on a Super M and to my best observatins it has a rebuild on it followed by a stuck piston and rings in #3 cylinder probably due to a rustout spot in the intake/ex. manifold. Serial # also indicates that originally it was a distillate engine and now it has domed or stepped pistons. Tractor had set up for ?? years but is all there and too good to give up on. Engine did not have much of a groove at top of cylinder. I 'll check end gap and verify the clyinders have tolerable taper prior to assembly. Wrist pin on #3 is also a little stiff what do you recommed? Does this pin float in the piston and the rod? Looks that way to me. If so, I guess I need to remove the pin, clean it, and lube it. While I am firing questions, the water pump on this tractor has a spring type arrangement in the center of the pulley. What is it's function as the pulley turns O K but I am concerned that the pump is stuck and merely slipping via this mechanism. As you can tell I can't speak farmall as good as I should but my dad and I just can't stand to see something old and not running stay that way.
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
