Re: ACE Plough Bottoms
Posted by MJ in the UK on December 01, 2005 at 00:47:21 from (195.92.168.176):
In Reply to: ACE Plough Bottoms posted by MJ in the UK on November 30, 2005 at 09:22:18:
Many thanks Hugh and George for your infomation.I have used a Hamilton built NO8 plough and i have parts and instruction book. In the UK IH started building them at Doncaster works in 1947 as the B8A plough When they put CAT2 3 point lift on the BM tractors in 1950 they made the B200 and B300 mounted ploughs using B8A frames and bottoms and fitting a 3 point lift frame. The B12 and B13 ploughs were CAT1 3point lift ploughs with much lighter frames. MJ
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
