Re: fuel bowl on a diesel
Posted by Michael Soldan on December 02, 2005 at 14:06:02 from (24.235.41.226):
In Reply to: fuel bowl on a diesel posted by john-wiz- on December 02, 2005 at 04:46:21:
John, as El Toro said..the fuel coming from the tank through the fuel bowl is not pressurized but is coming "gravity fed" at that point in the system, it is not untill the fuel reaches the pump does the system become under pressure...so shut the fuel flow off, remove the bowl and clean it, put it back on loosely and turn the fuel back on, this will allow the bowl to fill, when the bowl is "running over' tighten it the rest of the way. When you have the bowl off check the screen as well...interestingly My B250 had a bad screen and TSC had screens for 8N fords which were identical to the one on the B250, don't know if someone changed the outlet and bowl but it fit fine and works fine, you shouldn't have any problem but I have learned to keep a piece of cork board around so I can cut out a new gasket for the fuel bowls on my tractors, I also have some rubber gaskets, but cork seems to be more forgiving if you don't get it in place exactly to a tee....good luck...Mike in Exeter Ontario
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
