Timing a SA distributer Any suggestions welcome!
Posted by scott#2 on December 03, 2005 at 18:16:11 from (141.156.238.167):
I have searched hi and lo for the mark on the flywheel that you line up with the tab on the cover. I swear it is not there. Cleaned, rubbed polished searched, searched, searched. It just aint happenin.
Does anyone know hom many degrees btdc or atdc or is it at dead tdc that # 1 fires at? In other words, does anyone know exactly where in the stroke, #1 piston is, when that elusive mark on the flywheel is lined up?
I need to at least static time this thing before I try to fire it up. After that, I suppose I can mark the flywheel or pully and then check the advance, if it uses advance?
Thanks for any help,
scott#2
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
