Posted by LMack on March 10, 2009 at 19:46:47 from (98.66.223.102):
In Reply to: stuck 2424 posted by Simon bollin on March 10, 2009 at 18:32:25:
Is this a gasoline engine? If so, I would check to see if it has hydraulic lock. Pull the plugs and try spinning the engine. If it is a diesel then you will probably have to pull the injectors. A covered engine just doesn't freeze up with rust in as little as 5 months. Pouring oil, diesel fuel, or any other liquid down the exhaust pipe will cause the engine to lock up. Rain water or snow will do the same. larry
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
