Farmal M starter
Posted by Hayfarmer on December 19, 2005 at 21:39:24 from (66.243.239.207):
I had trouble with the starter on my SMTA. Pulled it apart and found the wire that goes between the hot brushes and hooks to the fields was burned in two. I think it probably got crimped and low battery and burned. I tried to find one of these here or even the wire to make a new one but was unable to find it. It is a really heavy wire. I tried a piece of heavy primary wire but it was too stiff. I now have about #10 primary wire in there and so far is ok but I would like to have the correct replacement if and when it goes. Does anyone know where I could get one? I have a delco number for it from the IH parts book but suspect it has been updated.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
