Farmall Tractors Discussion Board
H Carb Float height setting
Posted by john on January 04, 2000 at 13:26:25 from (198.70.112.100):
We just rebuilt an H carb which included a hot soak of the lower bowl. Upon reassy and test drive it would only run in gear for a few minutes before stalling. After stalling we would check for gas in the carb by loosening the pepcock in the lower bowl. It was empty causing the stalling. We then "raised" the float height by 1/4" and it seems to run better. Our question now is what is the actual spec for float height for the H??
Post A Followup
: Re: H Carb Float height setting
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
