Ahhh we have a problem
Posted by Larry806 on January 19, 2006 at 19:10:59 from (70.61.182.1):
Pulled the torque out of the MTA today. The torque clutch & planetary's look like new. Same old story the pins & springs are bad. I call the dealer to order.Gaskets, seals , No problem springs , check , pins , check , rubber plugs , check rollers _________ ah your not going to believe this there NA. just a min I'll just get them through Hy Capacity ahh NA from them too. Some has to have the rollers but who?
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
