Re: antique tractor screensaver?
Posted by williamf on January 21, 2006 at 09:32:08 from (69.19.14.16):
In Reply to: antique tractor screensaver? posted by Ronald on January 21, 2006 at 07:37:06:
I don't know for sure how it'll work with other operating systems, but if you use Windows XP you can make your own.
Create a new folder in My Pictures and name it, for instance, "Tractors."
Go to the Tractor Photos gallery on the left of this page and open a picture you want. Right click on the image, click on Save As. In the pop up, browse to the folder you created and save it there. Repeat, dozens of times if you want. After the first one it'll select that folder again until you tell it to stop.
Then open Control Panel, and Display. Open Screen Saver. Select My Pictures Slide Show. Click on settings and Browse to the folder you created. (If you leave it on My Pictures it'll show you everything in that folder.)
The other settings can change if you want, they're simple.
Good Luck, Wm
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
