Re: Milky rearend oil
Posted by Janicholson on February 05, 2006 at 14:18:12 from (66.173.50.105):
In Reply to: Milky rearend oil posted by oleduke on February 05, 2006 at 12:43:07:
The rear ends breath with temp change.
The condensation stays in and turns the fluid like chocklet milk. Leave it si for 10 days and drain out the water. check level and add as needed, see book. Cheap
Drain all fluid, let drip for 2-3 hrs.
Refill to level See book.
More expensive.
JimN
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
