Re: farmall super M 1958
Posted by El Toro on March 11, 2006 at 11:46:03 from (205.188.116.133):
In Reply to: farmall super M 1958 posted by jane riddle on March 11, 2006 at 09:35:25:
He needs to clean the engine block where the cylinder head was removed thoroughly and the head too if it needs it. He should use a new head gasket and torque it with a torque wrench in steps. He needs to start in the center of the head and tighten in both directions using a ratchet until just snug, then start torquing to 50 ft-lbs still going in both directions. Then increase the torque to 70 ft-lbs, then 90 ft-lbs until he reaches 110 ft-lbs. After he completes the head installation he needs to install the rocker arms for the valves. The valves need to be adjusted for clearance. Set the valve clearance at .020" cold. Before he adjusts these valves he needs to bring No1 piston to TDC on the compression stroke. Both of these valves should now be closed on No1 cylinder. Counting from the front of the engine near the radiator you can now adjust valves 1,2,3 & 5. Rotate the engine until No4 piston is at TDC and adjust 4, 6, 7 & 8. He needs to hold a thumb over the plug holes until he feels compression pushing against his thumb, then he will know he's on the compression stroke. When he's at No1 or No4 TDC the rotor should point to No1 and to No4 when one of these pistons is at TDC. Hal
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
