Re: SNOW DAY!!!
Posted by The tractor vet on March 13, 2006 at 07:49:42 from (64.179.117.111):
In Reply to: Re: SNOW DAY!!! posted by Kelly C on March 13, 2006 at 07:21:02:
Ahhhh grass hopper you must get all the timing marks on ft. of engine lined up then you must get the slot in oilpump drive to set at 30 degree of bolt hole in dist hold down So one must read book or one will be on here tryen to figure out why one can not get tractor to run or time up , and believe me timming is IMPORTANT ON 6 CYLINDER TRACTOR. So look in the book and you will see what i am talken about, before one get in trouble and find that you have to pull the engine out and pull the ft. cover AGAIN .
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
