Posted by Bob O2 Martin on April 09, 2009 at 16:47:05 from (69.66.16.186):
I have a leak on the throttle shaft on the engine side of the pump. It's always worse when the weather is cold. I guess the seal/o ring shrinks.
Someone had told me about the return tube on the backside of the pump, I believe, but I got the pump turned so I could check it and that wasn't the problem. When I force the throttle up and a little the drip turns into a small stream, so it pretty well points to the throttle shaft seal.
Question is what is the seal on the shaft (block side) and does it have to be installed from the inside of the pump or does it press in from the outside?
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
