Re: Internation 504 engine question
Posted by the tractor vet on April 01, 2006 at 06:56:09 from (64.179.117.144):
In Reply to: Internation 504 engine question posted by Mark H on April 01, 2006 at 06:41:18:
First off just where is this ticking noise comming from out of the exaust or valve cover or midway in the block or down in the oil pan area ? You need to refine the area of the tick as to corse of action to be taken . If it is comming out of the exhaust well then ya got and exhaust valve going to lunch and the head needs to come off and a valve job done then i would change the type of oil i was using and go with low ash 30 weight if it is comming from the valve cover area i would pull the valve cover and adjust the valves this is a tractor and needs and adjustment everyonce in awhile if it is comming from the middel to bottom then Huston You got a problem , could be broken ring wristpin starten to get loose or a rod bearing just starten to go bad . Go warm it up and listen to it and to narrow it down take a LONG wooden handeled screwdriver and hold it to your GOOD ear on the valve cover above each spark plug the down on the block then the pan under each plug your turn to play Doctor. and if the tractor slaps ya your playen doctor with the wrong tractor.
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
