Re: IH 140 Touch Control won't lift anymore
Posted by kx2b on May 09, 2006 at 14:05:13 from (216.144.246.91):
In Reply to: Re: IH 140 Touch Control won't lift anymore posted by KX2B on April 15, 2006 at 12:28:13:
Tried all the ideas for bleeding air and no results, so removed the pump. Took it to a hydraulic shop and had it checked. Pump and seal were in very good condition so ruled that out as a problem. Removed the gas tank and pulled the valve/cylinder unit. Noticed the control valve rubber boots were crumbling and snagging up in the yokes that work them back and forth. There were no boots on the pistons. Cleaned up that area and put new leather boots on the pistons and new rubber boots on the control valves. On the other side of the valve/cylinder unit, I removed the bolts, and head plate. On the lower right, corner, I found the tiny oriface plug/screen. Removed it and washed with brake cleaner. Also took a look at the Regulator valve parts - pushed the poppet open and gave it a squirt of compressed air. Torqued the head bolts down and re-installed the valve/cylinder unit, filled with Hy-Tran fluid - this time both Touch Controls responded and I followed the Operator's Manual for bleeding. Back in business Thanks to everone for all their suggestions and help. John
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
