Re: 140 IHC, Conversion kit
Posted by Nat 2 on May 19, 2006 at 05:20:15 from (64.80.110.33):
In Reply to: 140 IHC, Conversion kit posted by Gerald Hochberg on May 18, 2006 at 16:22:14:
Gerald, You will be seriously disappointed with these so-called "kits." These kits consist of an overpriced alternator and a photocopied sheet of "instructions" which tell you to "do whatever it takes to install the alternator and wire it up, and oh yeah, don't forget the ballast resistor between the switch and the ignition coil." It's not complicated, or difficult. The 140 is in fact one of the easiest to convert. Here's a high-level set of steps with some "gotchas" to look out for along the way: 1. Buy yourself an alternator. The Delco 10SI is a good choice for the Super A/C, 100,200,130,230,140,240 tractors. Bolts right in to the stock bracket with little to no modification necessary, using a piece of threaded rod. 2. Remove the original 6V battery, light bulbs, generator and voltage regulator. 3. Install the new alternator. 4. Wiring is a little complicated to describe in words. Bob M has a set of wiring diagrams he keeps posted on the web that will give you the general idea of what needs to be done. Someone will post the link shortly, with any luck. 5. Reverse the two small wires on the ignition coil and install a ballast resistor in between the ignition switch and the ignition coil. Or replace the original coil with a 12V coil. 6. Swap the two wires on the Amp gauge. 7. Install the battery, negative ground.
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
