Re: ELETRIC SYSTEM ON FARMALL M
Posted by El Toro on May 24, 2006 at 18:21:33 from (152.163.100.65):
In Reply to: ELETRIC SYSTEM ON FARMALL M posted by JIMMYJAYJOHNSON on May 24, 2006 at 16:22:55:
If this tractor has battery ignition, have you checked for battery voltage at the coil? If you are using (+ plus) ground on the battery, the plus terminal wire on your coil goes to the distributor. Use a volt meter or lite to check for voltage at the coil with ignition switch on. If you have voltage at the coil, pull the coil from the cap and hold within 1/8-1/4" of a good ground on the tractor while someone attempts to start tractor. You need to check the point gap, should be .020". Clean the points with some 320 grit and then clean them with a cotton swab dipped in alcohol. You should have a hot spark from that coil wire. Hal
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
