Re: Farmall C Smoking
Posted by BillWV on May 25, 2006 at 05:07:25 from (129.71.136.16):
In Reply to: Farmall C Smoking posted by tem on May 24, 2006 at 18:23:23:
My Super C was doing almost this exact thing. I vainly hoped maybe somehow that it didn't need rebuilt. (I even tried running it without the oil in the cup, too) But I pulled the head off, and the cylinders were noticeably worn, just by visual inspection. Piston slop was bad. I can't remember exactly what it was, but the ring end gap was on the order of 10 times what is was supposed to be. In other words, the cylinders and rings were worn out. I put in a sleeve/piston kit, and the smoking stopped. Better power, too.
Good luck,
Bill
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
