Re: Tried to Tune up the 460.....
Posted by Ron in Nebr on June 06, 2006 at 16:14:24 from (12.192.38.81):
In Reply to: Tried to Tune up the 460..... posted by Broomstacker on June 05, 2006 at 20:07:08:
Like mentioned earlier, next step should probably be a compression test. All the new tune-up parts in the world won't make a worn-out engine run good. Assuming that's ok, pull the plug wires one at a time to see if you can find which cylinder is missing. Did you replace the condensor when you replaced the points? There's not something restricting the air intake to the carb, is there? That wouldn't cause a definite pronounced miss, but it'd be worth checking. There's not a valve that's adjusted too tight or sticking is there?(compression test and finding out which cyl. is missing will help ya diagnose that if there is) If compression is ok, it really, without actually being there, sounds like something along the lines of point dwell problems....get that fixed so you know it's right...(cam on distributor shaft isn't worn out is it? check point gap at each spot)or better yet, spring for an electronic ignition kit and eliminate your point worries forever.
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
