Re: Re: Re: 300 farmall battery problem
Posted by AEB on June 22, 2006 at 06:44:21 from (204.116.91.4):
In Reply to: Re: Re: 300 farmall battery problem posted by TLO on July 05, 1999 at 10:06:49:
hey, what"s most likely happening with the tractor isn"t the battery at all provided it holds a charge. what you need to do to solve the problem completely is have the alternator tested at your local parts house (NAPA, Advance,ect.) That"s more than likely the trouble. Get a replacement alt. but get one of the GM 10si "one wire" ones or i know that advance auto carries a self exciting one the is truely one wire. the former one is about $33 and the latter is abour $50. the 10si should come with a wiring diagram in the box, but if it doesn"t, all ou do is run the bat. terminal to the starter or ammeter(if yours has one) and then put a jumper from the bat terminal on the alt to the smaller one one the side labeld with a 2 cast onto the case beside it. for the "1" terminal, there"s 2 ways to go. with the ammeter tahe a 100 ohm resistor, 1/2 watt resistor and go between it and the bat terminal on the back. Without the ammeter, you"ll need to pick up a panel mount light then run a wtre from the "1" terminal to a 100ohm resistor then to one of the 2 wires on the light. then hook up the other side of the light to a switched 12 volt source.
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
