Re: Check compression on Farmall M
Posted by CNKS on July 14, 2006 at 19:52:52 from (204.249.178.138):
In Reply to: Check compression on Farmall M posted by Don L C on July 14, 2006 at 16:03:42:
Remove all the plugs, use a compression gauge in the spark plug hole, and spin the starter. Do it first dry, them squirt motor oil in each cylinder and do it again. If the compression dry is low and increases significantly wet, you have a ring problem. If it is somewhat low and stays the about the same, the valves are leaking. More important than the actual numbers is the difference -- the cylinders should be within 10% of each other. If you have a gasoline engine with standard pistons, the original compression was about 120. How much less than that you can go and still have a decent engine, I don't know. IMO, 90-100 is good, 80 questionable. Others will have different opinions.
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
