Re: Help Me Understand...Bearing Pre-load
Posted by Janicholson on July 21, 2006 at 15:40:03 from (66.173.50.60):
In Reply to: Help Me Understand...Bearing Pre-load posted by Erik in WI on July 20, 2006 at 17:11:31:
Tapered roller bearings run with axial load applied all the time. This load is a combination of the loads applied from the shaft they are controlling, and pre-load. Pre-load is applied by rotating adjusters, Crushing a special sleeve, removing or adding shims, or shim gaskets. The result is to put a partial load on the rollers even when there is no load on the shaft. Tapered roller bearings need as much as 2-to-5% of their rated max load used as pre-load to keep them aligned and the shaft located. The system load is measured in several ways some times with nut tightness on a shaft, sometimes by rotational force on the assembly, and sometimes by measurment and mathmatics. The only way a seperate preload could be involved is if the case was distorted by the loading of the first shaft. Not a best design situation, and not applicable to two axles on the tractor (my opinion) JimN
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
