Re: 1952-3 Super M hydraulics
Posted by john d on July 25, 2006 at 16:36:49 from (69.130.178.195):
In Reply to: 1952-3 Super M hydraulics posted by jack-Iowa on July 23, 2006 at 13:55:18:
There may be a dipstick in the filler neck for the pump. That's under the "knob" on the fill pipe that comes straight up from the pump on the top of the casting opposite the starter.
Probably at least half of those dipsticks have disappeared over the years; some have simply fallen into the reservoir below. You can probably find a post in the archives about the proper length for the dipstick. I think they were made in two pieces linked together in the middle so it would clear the gas tank when removed.
The "Lift-All" or belly-pump in the Stage 1 SM uses SAE 30 NON-detergent oil. You can find the stuff at most autoparts stores, and sometimes at Wal-Mart. They WILL operate on IH HY-Tran oil that is used in later tractors, but if the pump is worn, you may not get full pressure.
If you don't find the info on the dipstick, just add oil until it completely lifts whatever you're trying to lift, then add just a little more! Don't ever let it run dry!
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
