Re: Troubleshooting a 340U FastHitch
Posted by the tractor vet on August 02, 2006 at 21:14:42 from (75.24.34.189):
In Reply to: Troubleshooting a 340U FastHitch posted by PaulW_NJ on August 02, 2006 at 21:04:33:
First check the linkage going back to the hitch , there is a roll pin that will shear and if that shears then the hitch will go gooffy , next if that is not the problem then remove the cover on the teladepth valve and look at the gears as sometime they strip off a couple teeth and this makes things go goooooofffffy.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
