Re: any tips or tricks to changing trans cases on
Posted by Roger46 on August 03, 2006 at 19:06:10 from (69.58.132.64):
In Reply to: any tips or tricks to changing trans cases on M posted by Paul G. in Mn on August 03, 2006 at 16:20:23:
Paul, I just changed the trans case on my Cub when I rebuilt it. I think the biggest problem is getting the ring and pinion gear aligned correctly. I had the same experience with my MD several years ago when I dropped and broke the bearing housing and had to realign the ring and pinion gear. The gear alignment process is a trial and error process of changing shims and moving shims from one side to the other. IH must have had some kind of a fixture they used for doing it originally in the factory as they couldn't have aforded to reassemble the gears multiple times. The manual tells how to do it, so if you follow that you should be OK, but just takes time. If it is wrong and you use the tractor for any pulling you can destroy the gears. Roger
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
