Re: what varnish should I use on paper pulley
Posted by Andy Martin on August 15, 2006 at 05:07:44 from (64.219.39.195):
In Reply to: what varnish should I use on paper pulley posted by arod on August 14, 2006 at 17:21:57:
I just use an exterior spar varnish and let it soak in to the paper. It will help bind things together.
On the one's I use, I put a little used motor oil on them, and it soaks in pretty well. It is good if they sit outside all year.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
