Semi OT - IH Industrial UB220 motor carb parts
Posted by Tip on August 27, 2006 at 18:20:52 from (71.2.45.69):
I have a Galion 503 motor grader with an IH UB220 industrial
motor. The carb is giving me fits. I either need a replacement
carb or a rebuild kit.
The machine has been sitting a while and is a little rough. I am
leaning toward replacing the carb as there is quite a bit of
pitting in the bore for the accelerator pump (and in other parts
as well) - don't know if it will really matter, but I don't think I can
get a good seal, even with an overhaul kit.
Suggestions for parts? Bates Corp? Others?
Thanks, Tip
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
