H engine, water jacket FULL of rust scale
Posted by arod on August 29, 2006 at 16:18:03 from (130.20.51.229):
took the side cover off and you know how there are those two metal towers on the inside of that water cover...? well they are rusted away, gone. Took that cover off because the drain plug was so choked with scale.
Did the previous owner not put in antifreeze, and just run on straight water?
Also, Can these H engines take some rust abuse in there and still survive, how does one guage when the rust is too severe?
By punching a hole through the casting into the cylinder with a screwdriver... ha ha ha.
no really, this tractor is quickly becoming a parts machine, though I did want to salvage the block, looks like I can forget that idea, huh.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
