Re: 826 HYDRAULIC PROBLEM
Posted by the tractor vet on September 04, 2006 at 07:41:14 from (75.24.11.52):
In Reply to: Re: 826 HYDRAULIC PROBLEM posted by Allan In NE on September 04, 2006 at 06:59:56:
Make sure that the T/A and clutch adjustments are correct like i have layed out before as the double shift is usual caused by the dump valve being out of adjustment . For get the book on other then clutch free travel the rest is simple but does require two people one to set in the seat and do the pedal pushen and the other to get his hands dirty . Set the free travel on the clutch first then go to the trans brake and pull the hair pin out then the clevis pin after ya broke the lock nut loose put the clutch to the floor with the engine OFF and hold the trans brake lever all the way back adjust the clevis out till the pin will slid in freeley then let the clutch pedal up and adjust the clevis out one to one and a half turns more install the pin and hair pin and lock down the lock nut . Next start the engine and at and ideal and with the transmission in N park loc ingaged loosen the T/A dump valve adjust bolt and back off about 6 or 7 turns .next push the clutch pedal down to the stop lug and hold there now turn the dump valve bolt in till the T/A lube pressure lite just comes on if the lite does not work fix that first Stop as soon as the teltale lite comes on shut down the engine let the clutch pedal up and give the dump valve bolt one more complet turn in and lock the lock nut down . all done no fancy massuren that is never done wright in the first place this way works vary well. I am out of here going to chop corn.
Home
| Forums
Today's Featured Article -
Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
