Re: therm-sifon cooling system
Posted by RAW in IA on October 11, 2006 at 17:37:36 from (12.216.216.73):
In Reply to: therm-sifon cooling system posted by dennis repaal on October 11, 2006 at 13:40:32:
As others have said, definately use anti-freeze. Dad's C had the thmp pickup unit at the return pipe to the engine,(bottom of radiator). Would never come off cold unless the tractor was low on water and it didn,t circulate, andby then you were in trouble. They do get quite hot at the top of radiator, that is what makes the system work, hot water rises and cold descends. My Cuib will get up to almost 200 going down the road without a load, but you can hold your hand on the return pipe back to the engine. If it isn't cooling, could be the radiator is pluged so enough air doesn't go through it, or uner some conditions a bad or misssing fan shroud can cause them to overheat.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
