706 shifting problem
Posted by SteveGr on November 05, 2006 at 05:31:56 from (207.118.159.60):
I just acquired a 706 and found that it would not stay in high range , it would jump out under aload. I checked the external linkage and that appeared fine. I manually shifted it on top of the cover and it still jumps out. I pulled the top cover which I found to have been replaced and could find nothing out of whack. I then looked at the shift collar and could see no problems, also looked at the high gear splines and could see no excesseive wear. I then manually slid the shift collar and engaged high range and started the tractor and put a load on it and it did not jump out of gear and worked fine. The shift fork had been built up but appeared straight. open to any ideas. Thanks in advance.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
