Inernational 444 Transmission Problem
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by David Anderson on February 03, 2000 at 08:25:26 from (198.164.206.250):
We have an International 444. One day sitting idling on a flat garage floor something jammed in the transmission causing the motor to stall. It could be started again as long as the clutch was in. It could be shifted to any gear and hi-low range, but nothing changed the jam. We took it for service and nothing could be found broken or needing replacement. It appeared to have hi-low engaged at the same time, but no apparent reason why. It was put back together and is working OK for now but I expect it will jam again. Has anyone had a similar situation or can offer an idea of what may be wrong?
Thanks, David
Post A Followup
: Re: Inernational 444 Transmission Problem
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
