Re: what's all the pipe plugs for on a cub TC?
Posted by Harold Hubbard on December 23, 2006 at 03:29:47 from (66.6.176.23):
In Reply to: what's all the pipe plugs for on a cub TC? posted by M clunker on December 22, 2006 at 19:42:10:
If it's anything like the Touch Control on the C, Super C etc. the block has a lot of internal oil passages. These all had to be drilled through from the outside, and then were plugged when the drilling was finished. The C engine is the same, there is a row of plugs along the block where they drilled the oil passages to the main bearings.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
